Toshiba Satellite L305D-S5895 Battery Replacement
  1. Toshiba Satellite L305D-S5895 Battery Replacement, Battery Replacement: step 1, image 1 of 1
    • Make sure switch with the number 1 is moved to the right, in the unlocked position.
  2. Toshiba Satellite L305D-S5895 Battery Replacement: step 2, image 1 of 1
    • Slide and hold switch number 2 to the left, and use your finger to pry battery out using the slot to the right of the switch.
  3. Toshiba Satellite L305D-S5895 Battery Replacement: step 3, image 1 of 1
    • Remove the battery from the laptop.
Daniel Matheson
355 Reputation
3 Guides authored
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 262
