Toshiba Satellite L305D-S5895 Hard Drive Replacement
  1. Toshiba Satellite L305D-S5895 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Toshiba Satellite L305D-S5895 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Locate these two screws that you will need to remove.
    • Undo these two screws with the Phillips #0 Screwdriver.
  2. Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 2, image 1 of 2 Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 2, image 2 of 2
    • Use your finger to lift and remove the cover to the Hard Drive.
  3. Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 3, image 1 of 3 Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 3, image 2 of 3 Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 3, image 3 of 3
    • Pull the black ribbon back and up to remove the Hard Drive.
  4. Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 4, image 1 of 2 Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 4, image 2 of 2
    • Remove the cover to reveal the hard drive.
  5. Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 5, image 1 of 3 Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 5, image 2 of 3 Toshiba Satellite L305D-S5895 Hard Drive Replacement: step 5, image 3 of 3
    • Pull out the hard drive using the ribbon attached to it.
Daniel Matheson
355 Reputation
3 Guides authored
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 303
