Toshiba Satellite L305D-S5895 Keyboard Replacement
  1. Toshiba Satellite L305D-S5895 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
  2. Toshiba Satellite L305D-S5895 Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite L305D-S5895 Keyboard Replacement: step 2, image 2 of 2
    • Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
  3. Toshiba Satellite L305D-S5895 Keyboard Replacement: step 3, image 1 of 2 Toshiba Satellite L305D-S5895 Keyboard Replacement: step 3, image 2 of 2
    • After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop.
    • Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
  4. Toshiba Satellite L305D-S5895 Keyboard Replacement: step 4, image 1 of 1
    • Lift the keyboard up in order to remove the cable.
  5. Toshiba Satellite L305D-S5895 Keyboard Replacement: step 5, image 1 of 3 Toshiba Satellite L305D-S5895 Keyboard Replacement: step 5, image 2 of 3 Toshiba Satellite L305D-S5895 Keyboard Replacement: step 5, image 3 of 3
    • Notice the two white tabs on the compartment holding the cable.
    • Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
Tyler GLick
101 Reputation
1 Guide authored
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Member of UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 12
All Time: 346
