Toshiba Satellite L455-S5046 Hard-drive Replacement
  1. Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: step 1, image 2 of 2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 Hard-drive Replacement, Hard-drive: step 2, image 1 of 1
    • Locate the hard drive in the upper right corner on the back of the computer.
    • Unscrew the 2 Phillips #0 7-mm screws holding the cover in place and remove the cover.
  3. Toshiba Satellite L455-S5046 Hard-drive Replacement: step 3, image 1 of 1
    • Once the cover is off, the hard drive will be exposed, carefully pull it out to the right.
Daryl Spurgeon
610 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 301
