Toshiba Satellite L455-S5046 Keyboard Replacement
  1. Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Lift the plastic strip above the keyboard. If you use a lever to pick up the left edge it should pop off.
    • Use the Phillips #0 screwdriver to remove the two indicated 5-mm screws.
  2. Toshiba Satellite L455-S5046 Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite L455-S5046 Keyboard Replacement: step 2, image 2 of 2
    • Remove the keyboard slowly. It will be attached to the laptop by a plastic connector, which can be disconnected from the laptop by pulling gently.
Daryl Spurgeon
610 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 398
