Toshiba Satellite L455-S5046 Optical Drive Replacement
Video Overview
  1. Toshiba Satellite L455-S5046 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Unscrew 1 Phillips #0 7-mm screw on the back of the computer.
  2. Toshiba Satellite L455-S5046 Optical Drive Replacement: step 2, image 1 of 1
    • Lift the plate and gently pull it away from yourself, until it is removed.
  3. Toshiba Satellite L455-S5046 Optical Drive Replacement: step 3, image 1 of 1
    • Unscrew the 1 Phillips #0 7-mm screw, located on the right side where the silver tabs of the optical drive poke out.
  4. Toshiba Satellite L455-S5046 Optical Drive Replacement: step 4, image 1 of 2 Toshiba Satellite L455-S5046 Optical Drive Replacement: step 4, image 2 of 2
    • The optical drive is partially visible and push it to the right.
    • The optical drive should pop out on the right side, and you can gently pull it out.
Daryl Spurgeon
610 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 193
