Toshiba Satellite L505 Laptop Keyboard Replacement
  1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: step 1, image 1 of 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: step 1, image 2 of 3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite L505 Laptop Keyboard Replacement: step 2, image 2 of 2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Keyboard Replacement: step 3, image 1 of 2 Toshiba Satellite L505 Laptop Keyboard Replacement: step 3, image 2 of 2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Keyboard Replacement: step 4, image 1 of 3 Toshiba Satellite L505 Laptop Keyboard Replacement: step 4, image 2 of 3 Toshiba Satellite L505 Laptop Keyboard Replacement: step 4, image 3 of 3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
Matias
1,019 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,235
