Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement
  1. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Keyboard: step 1, image 1 of 3 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Keyboard: step 1, image 2 of 3 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Keyboard: step 1, image 3 of 3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 2, image 1 of 2 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 2, image 2 of 2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 3, image 1 of 2 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 3, image 2 of 2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 4, image 1 of 3 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 4, image 2 of 3 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 4, image 3 of 3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
  5. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Optical Drive: step 5, image 1 of 2 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Optical Drive: step 5, image 2 of 2
    • Turn the laptop upside down.
    • Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • There are 2 screws labeled F4, the correct screw is the one closer to the hard drive.
  6. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 6, image 1 of 2 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 6, image 2 of 2
    • Gently slide the optical drive out of the device.
  7. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Battery: step 7, image 1 of 1
    • Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
  8. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Palm Rest Assembly: step 8, image 1 of 3 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Palm Rest Assembly: step 8, image 2 of 3 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Palm Rest Assembly: step 8, image 3 of 3
    • Unscrew all of the screws marked on the underside of the laptop.
    • Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
    • Remove the three flat screws in the port where the Optical drive is housed in.
  9. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 9, image 1 of 2 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 9, image 2 of 2
    • Remove the keyboard and once that has been done, remove the screw marked "16."
    • Disconnect all of the cables with a blue circle.
  10. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 10, image 1 of 3 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 10, image 2 of 3 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: step 10, image 3 of 3
    • Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
Matias
1,019 Reputation
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 418
