Toshiba Satellite L755-S5244 Optical Drive Replacement
  1. Toshiba Satellite L755-S5244 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
    • Before anything start by disconnecting the battery.
  2. Toshiba Satellite L755-S5244 Optical Drive Replacement: step 2, image 1 of 2 Toshiba Satellite L755-S5244 Optical Drive Replacement: step 2, image 2 of 2
    • Next, unscrew the RAM cover and carefully remove it. Then, locate and unscrew the optical drive screw.
  3. Toshiba Satellite L755-S5244 Optical Drive Replacement: step 3, image 1 of 1
    • Carefully remove the optical drive.
  4. Toshiba Satellite L755-S5244 Optical Drive Replacement: step 4, image 1 of 1
    • Finally, detach the mounting bracket from the optical drive in order to attach it to the new optical drive then follow the steps in reverse to reassemble it.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 366
