Toshiba Satellite L755D-S5150 RAM  Replacement
Kyler Clonts
Kyler Clonts and 6 other contributors
Last updated on December 28, 2016
5 minutes
Easy
Introduction
Go to step 1
Follow this guide if you need to replace or upgrade your RAM. Sometimes people want to upgrade their RAM rather than replace it because the RAM helps your computer read data faster.
Tools
  1. Toshiba Satellite L755D-S5150 RAM  Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite L755D-S5150 RAM  Replacement, Battery: step 1, image 2 of 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 RAM  Replacement, RAM Chip: step 2, image 1 of 3 Toshiba Satellite L755D-S5150 RAM  Replacement, RAM Chip: step 2, image 2 of 3 Toshiba Satellite L755D-S5150 RAM  Replacement, RAM Chip: step 2, image 3 of 3
    • Using the Phillips PH00 screwdriver unscrew the three 4mm screws for the cover of the Ram compartment.
    • Now remove the cover for the Ram compartment.
  3. Toshiba Satellite L755D-S5150 RAM  Replacement: step 3, image 1 of 2 Toshiba Satellite L755D-S5150 RAM  Replacement: step 3, image 2 of 2
    • Using both hands, gently push the two metal claps on either side of the top RAM chip outward.
    • The RAM chip will then pop up at an angle, allowing you to pull it out.
    • Repeat the above step for the second RAM chip
Kyler Clonts
258 Reputation
2 Guides authored
USF Tampa, Team 2-5, Sullivan Fall 2016 Member of USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 404
