Toshiba Satellite M305D-S4829 RAM Replacement
  1. Toshiba Satellite M305D-S4829 RAM Replacement, RAM: step 1, image 1 of 1
    • Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Remove the back panel.
  2. Toshiba Satellite M305D-S4829 RAM Replacement: step 2, image 1 of 3 Toshiba Satellite M305D-S4829 RAM Replacement: step 2, image 2 of 3 Toshiba Satellite M305D-S4829 RAM Replacement: step 2, image 3 of 3
    • Locate the two clips holding the RAM chip in place.
    • Apply pressure to each clip, pulling them away from the RAM.
    • One end of the RAM will pop out.
  3. Toshiba Satellite M305D-S4829 RAM Replacement: step 3, image 1 of 2 Toshiba Satellite M305D-S4829 RAM Replacement: step 3, image 2 of 2
    • Gently pull RAM out as shown.
  4. Toshiba Satellite M305D-S4829 RAM Replacement: step 4, image 1 of 1
    • To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • Gently push down on the RAM chip until it snaps securely into place.
Michael Jensen
425 Reputation
6 Guides authored
Cal Poly, Team 4-3, Regan Spring 2011 Member of Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 2,718
