Toshiba Satellite M35X-S114 RAM Replacement
  1. Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: step 1, image 1 of 2 Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: step 1, image 2 of 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: step 2, image 1 of 2 Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: step 2, image 2 of 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: step 3, image 1 of 2 Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: step 3, image 2 of 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: step 4, image 1 of 3 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: step 4, image 2 of 3 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: step 4, image 3 of 3
    • Locate the RAM cover around the middle left-hand side of the device.
    • Locate the screw on the RAM cover.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
    • Carefully remove the RAM access hatch.
  5. Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: step 5, image 1 of 2 Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: step 5, image 2 of 2
    • Locate the four silver clips holding the RAM sticks.
    • There is a total of two RAM chips and four silver clips. Two silver clips hold one RAM stick. Remove one RAM stick at a time.
    • Use your fingers from separate hands to pull back the two silver clips away from the sides of the RAM stick.
    • Repeat this step for the other RAM stick.
  6. Toshiba Satellite M35X-S114 RAM Replacement: step 6, image 1 of 1
    • Gently pull the RAM stick out from its slot.
Christian Mayorga
219 Reputation
2 Guides authored
CSU Fullerton, Team 2-4, Bruce Fall 2014 Member of CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 459
