Toshiba Satellite M45 Cooling Unit Replacement
  1. Toshiba Satellite M45 Cooling Unit Replacement, Cooling Unit: step 1, image 1 of 3 Toshiba Satellite M45 Cooling Unit Replacement, Cooling Unit: step 1, image 2 of 3 Toshiba Satellite M45 Cooling Unit Replacement, Cooling Unit: step 1, image 3 of 3
    • Remove the cover from the cooling unit.
  2. Toshiba Satellite M45 Cooling Unit Replacement: step 2, image 1 of 2 Toshiba Satellite M45 Cooling Unit Replacement: step 2, image 2 of 2
    • Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
  3. Toshiba Satellite M45 Cooling Unit Replacement: step 3, image 1 of 1
    • Follow the tear-down guide until you have access to the fan unit on the motherboard.
  4. Toshiba Satellite M45 Cooling Unit Replacement: step 4, image 1 of 3 Toshiba Satellite M45 Cooling Unit Replacement: step 4, image 2 of 3 Toshiba Satellite M45 Cooling Unit Replacement: step 4, image 3 of 3
    • Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
Stephen
370 Reputation
3 Guides authored
Cal Poly, Team 10-42, Garner Spring 2010 Member of Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 5,466
