Toshiba Satellite M45 Display Replacement
  1. Toshiba Satellite M45 Display Replacement, Keyboard: step 1, image 1 of 3 Toshiba Satellite M45 Display Replacement, Keyboard: step 1, image 2 of 3 Toshiba Satellite M45 Display Replacement, Keyboard: step 1, image 3 of 3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  2. Toshiba Satellite M45 Display Replacement: step 2, image 1 of 3 Toshiba Satellite M45 Display Replacement: step 2, image 2 of 3 Toshiba Satellite M45 Display Replacement: step 2, image 3 of 3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
  3. Toshiba Satellite M45 Display Replacement, Display: step 3, image 1 of 1
    • Remove the 2-3 pieces of black electrical tape covering the black-and-white antenna cable.
    • Close the display, flip the laptop over, and disconnect the black-and-white antenna cables from the Wi-Fi card.
    • Flip the laptop back over and open the display.
  4. Toshiba Satellite M45 Display Replacement: step 4, image 1 of 3 Toshiba Satellite M45 Display Replacement: step 4, image 2 of 3 Toshiba Satellite M45 Display Replacement: step 4, image 3 of 3
    • Remove the two Phillips #1 screws securing the display hinges.
    • It is recommended to keep the screws in a small cup so that you don't lose them.
    • Remove the four Phillips #1 screws on the back of the laptop.
  5. Toshiba Satellite M45 Display Replacement: step 5, image 1 of 1
    • Gently pull up on the display's video connector to remove it.
    • Remove the black-and-white antenna cable from the groove.
    • Your display can now be removed.
3 other people completed this guide.
Aryn Pauly
1 Reputation
2 Guides authored
Cal Poly, Team 10-42, Garner Spring 2010 Member of Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 17
All Time: 8,140
