Toshiba Satellite M45 Keyboard Replacement
  1. Toshiba Satellite M45 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Toshiba Satellite M45 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Toshiba Satellite M45 Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  2. Toshiba Satellite M45 Keyboard Replacement: step 2, image 1 of 3 Toshiba Satellite M45 Keyboard Replacement: step 2, image 2 of 3 Toshiba Satellite M45 Keyboard Replacement: step 2, image 3 of 3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
5 other people completed this guide.
Aryn Pauly
1 Reputation
2 Guides authored
Cal Poly, Team 10-42, Garner Spring 2010 Member of Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 8,375
