Toshiba Satellite M45 RAM Replacement
  1. Toshiba Satellite M45 RAM Replacement, RAM: step 1, image 1 of 3 Toshiba Satellite M45 RAM Replacement, RAM: step 1, image 2 of 3 Toshiba Satellite M45 RAM Replacement, RAM: step 1, image 3 of 3
    • Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
    • Then, use a the blue iFixit Opening Tool to pry the cover panel off.
    • Push on to the RAM tabs to disconnect the RAM form the device.
    • The RAM will pop off from the socket. Gently pull the RAM out of the socket.
3 other people completed this guide.
Sophie Schneider
82 Reputation
3 Guides authored
Cal Poly, Team 10-42, Garner Spring 2010 Member of Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 4,778
