Toshiba Satellite M55-S135 Battery Replacement
  1. Toshiba Satellite M55-S135 Battery Replacement, Battery: step 1, image 1 of 1
    • Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
    • Slide the unlock switch in the top left-hand corner to the left/unlock position.
  2. Toshiba Satellite M55-S135 Battery Replacement: step 2, image 1 of 1
    • Hold the switch in upper right-hand corner to the right.
    • With the switch held open, pull the battery straight away from the laptop.
Matthew Trinh
63 Reputation
4 Guides authored
Cal Poly, Team 7-11, Maness Winter 2013 Member of Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 693
