Toshiba Satellite M55-S135 Hard Drive Replacement
  1. Toshiba Satellite M55-S135 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Use the Phillips 00 screwdriver to remove the 3.62mm screw.
  2. Toshiba Satellite M55-S135 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the plastic cover from the laptop.
  3. Toshiba Satellite M55-S135 Hard Drive Replacement: step 3, image 1 of 1
    • Pull the black plastic tab horizontally away from the hard drive to disconnect and remove the hard drive from the laptop.
  4. Toshiba Satellite M55-S135 Hard Drive Replacement: step 4, image 1 of 1
    • Use the Phillips 00 screwdriver to remove the four 6.50mm screws on the sides of hard drive.
  5. Toshiba Satellite M55-S135 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Satellite M55-S135 Hard Drive Replacement: step 5, image 2 of 2
    • Use the Phillips 00 screwdriver to remove the other four 6.50mm screws on hard drive.
    • Remove the washer strips (the metal strips that the screws held down) from the hard drive.
  6. Toshiba Satellite M55-S135 Hard Drive Replacement: step 6, image 1 of 1
    • Pull the black tab away from the hard drive to separate the hard drive and the casing.
2 other people completed this guide.
Matthew Trinh
63 Reputation
4 Guides authored
Cal Poly, Team 7-11, Maness Winter 2013 Member of Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Members
5 Guides authored
2 Comments
I have a regular SATA 2.5 hard drive and it won't fit my M55-S1001. Is there something else I need??
Matthew Halbert - Reply
According to http://www.rakuten.com/prod/120gb-hard-d..., your hard drive is the right size. If it doesn't fit, check to see if the pins connect correctly and if your laptop accepts a SATA drive and not a PATA drive; this image can help http://www.laptopking.com/sata_identify.....
Next, check if you're inserting it correctly. I haven't experienced replacing the hard drive with the M55-S1001, but I assume it's the same method as the M55-S135 (though it could be different).
I'm unsure if there's anything else you would need besides the correct type of screwdriver to unlock the casing but I doubt it.
Matthew Trinh - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 3,970
