Introduction
This guide will illustrate how to replace the optical drive in your Toshiba Satellite.
Orient the laptop so that it is closed, faced down and has the battery facing away from you.
Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
Use the Phillips #00 screwdriver to remove the 6.50mm screw holding the gray metal bracket in place.
Almost done!
