Toshiba Satellite M55-S135 RAM Replacement
  1. Toshiba Satellite M55-S135 RAM Replacement, RAM: step 1, image 1 of 1
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 RAM Replacement: step 2, image 1 of 1
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 RAM Replacement: step 3, image 1 of 2 Toshiba Satellite M55-S135 RAM Replacement: step 3, image 2 of 2
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
Matthew Trinh
63 Reputation
4 Guides authored
Cal Poly, Team 7-11, Maness Winter 2013 Member of Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,389
