Toshiba Satellite P105-S6147 Cooling Fan Replacement
  1. Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: step 1, image 1 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: step 1, image 2 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: step 1, image 3 of 3
    • Begin by placing the laptop face down on a flat surface.
    • The battery is located in the bottom left hand corner of the device.
    • Slide the lock switch on the battery to the unlocked position.
    • Slide the release lever on the battery towards the lock switch. The battery should now rotate out of its dock in the laptop.
  2. Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 2, image 1 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 2, image 2 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the casing located next to the battery.
    • Using a #0 Phillips screwdriver, remove the two 4 mm screws.
    • Use the precision tweezers to disconnect the white and black wire from the device.
    • Remove the thin black wire from the device.
  3. Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 3, image 1 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 3, image 2 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 3, image 3 of 3
    • Open the remaining casings using a #0 Phillips screwdriver.
    • Remove all visible screws on the bottom of the laptop to complete this step.
  4. Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 4, image 1 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 4, image 2 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 4, image 3 of 3
    • Hold the back cover slightly open.
    • Use the precision tweezers to disconnect the two ribbon cables at the bottom of the laptop.
    • Open the small black clips to free the ribbon cables.
    • Remove the back cover.
  5. Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 5, image 1 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 5, image 2 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 5, image 3 of 3
    • Locate the white plug in the upper right hand corner of the laptop.
    • Use the iFixit opening tools to apply even, backwards pressure to each side of the plug until the plug is free from the motherboard.
  6. Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 6, image 1 of 2 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 6, image 2 of 2
    • Locate the ribbon cable on the bottom of the laptop.
    • Open the small black clip that is holding the ribbon cable.
    • Gently remove the ribbon cable with the precision tweezers.
  7. Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 7, image 1 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 7, image 2 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 7, image 3 of 3
    • Locate the white plug next to the ribbon cable that was removed in the previous step.
    • Gently unplug the plug with your hand or the blue iFixit opening tools.
  8. Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 8, image 1 of 1
    • Remove the motherboard from the laptop casing.
  9. Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: step 9, image 1 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: step 9, image 2 of 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: step 9, image 3 of 3
    Buy
    • Use the precision tweezers to remove the metal cover off the top of the cooling fan. It should "pop" off with little effort.
    • Flip over the motherboard.
    • The cooling fan is now located in the upper left-hand corner of the motherboard.
  10. Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 10, image 1 of 2 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 10, image 2 of 2
    • Remove the two 5 mm screws located at the bottom right of the cooling fan.
    • The cooling fan housing is now free from the motherboard.
  11. Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 11, image 1 of 2 Toshiba Satellite P105-S6147 Cooling Fan Replacement: step 11, image 2 of 2
    • Locate the white plug connecting the cooling fan to the motherboard.
    • Gently pull on the plug to disconnect the cooling fan from the motherboard.
    • Remove the cooling fan from the motherboard.
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 14
All Time: 250
