Toshiba Satellite P205-S8811 Disk Drive Replacement
  1. Toshiba Satellite P205-S8811 Disk Drive Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite P205-S8811 Disk Drive Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Disk Drive Replacement: step 2, image 1 of 2 Toshiba Satellite P205-S8811 Disk Drive Replacement: step 2, image 2 of 2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Disk Drive Replacement, Disk Drive: step 3, image 1 of 1
    • Remove the 8mm Phillips #1 screw that holds the disk drive in place.
  4. Toshiba Satellite P205-S8811 Disk Drive Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to pry out the disk drive.
  5. Toshiba Satellite P205-S8811 Disk Drive Replacement: step 5, image 1 of 2 Toshiba Satellite P205-S8811 Disk Drive Replacement: step 5, image 2 of 2
    • Once the disk drive becomes loose, slowly slide it out and set it aside.
Bradley Johnson
214 Reputation
2 Guides authored
Cal Poly, Team 2-8, Amido Winter 2014 Member of Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 429
