Toshiba Satellite P205-S8811 RAM Replacement
  1. Toshiba Satellite P205-S8811 RAM Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite P205-S8811 RAM Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 RAM Replacement: step 2, image 1 of 2 Toshiba Satellite P205-S8811 RAM Replacement: step 2, image 2 of 2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 RAM Replacement, RAM: step 3, image 1 of 1
    • Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
  4. Toshiba Satellite P205-S8811 RAM Replacement: step 4, image 1 of 1
    • Using a Phillips-head screwdriver, unscrew and remove the screw holding the RAM slot cover in place.
  5. Toshiba Satellite P205-S8811 RAM Replacement: step 5, image 1 of 2 Toshiba Satellite P205-S8811 RAM Replacement: step 5, image 2 of 2
    • Lift and remove the RAM slot cover.
  6. Toshiba Satellite P205-S8811 RAM Replacement: step 6, image 1 of 2 Toshiba Satellite P205-S8811 RAM Replacement: step 6, image 2 of 2
    • To remove the first RAM chip, gently press outward on the tabs on both sides of the chip
    • The RAM chip should pop up after releasing the tabs.
  7. Toshiba Satellite P205-S8811 RAM Replacement: step 7, image 1 of 1
    • Using your fingers, remove the RAM chip by gently pulling it out of the RAM slot.
  8. Toshiba Satellite P205-S8811 RAM Replacement: step 8, image 1 of 2 Toshiba Satellite P205-S8811 RAM Replacement: step 8, image 2 of 2
    • To remove the second RAM chip, repeat the previous steps
Davin
271 Reputation
2 Guides authored
Cal Poly, Team 2-8, Amido Winter 2014 Member of Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 487
