Toshiba Satellite P50W-C Hard Drive Replacement
  1. Toshiba Satellite P50W-C Hard Drive Replacement, Back Cover: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Hard Drive Replacement: step 2, image 1 of 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Hard Drive Replacement: step 3, image 1 of 2 Toshiba Satellite P50W-C Hard Drive Replacement: step 3, image 2 of 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Remove the back cover of the device.
  5. Toshiba Satellite P50W-C Hard Drive Replacement: step 5, image 1 of 1
    • Remove the hard drive from the device by gently pulling on the blue plastic hard drive cover.
  6. Toshiba Satellite P50W-C Hard Drive Replacement: step 6, image 1 of 2 Toshiba Satellite P50W-C Hard Drive Replacement: step 6, image 2 of 2
    • Disconnect the hard drive from the mother board by gently pulling out the black connector.
2 other people completed this guide.
Sarah Fordjour
450 Reputation
4 Guides authored
USF Tampa, Team S3-G2, Cannon Fall 2017 Member of USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Members
7 Guides authored
2 Comments
Can you change the touch panel of toshibasatelliteP50W-B1038.
rizwana rizi - Reply
Hi dear,
My laptop bios was crashed,
I need to radius 15 p50w-c-104 bios dump file.
can you help me please.?
labexperiance@gmail.com
thank you
Mustafa SAYIN - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 703
