Toshiba Satellite P50W-C RAM Replacement
  1. Toshiba Satellite P50W-C RAM Replacement, Back Cover: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C RAM Replacement: step 2, image 1 of 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C RAM Replacement: step 3, image 1 of 2 Toshiba Satellite P50W-C RAM Replacement: step 3, image 2 of 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C RAM Replacement, RAM: step 4, image 1 of 1
    • Locate the RAM.
  5. Toshiba Satellite P50W-C RAM Replacement: step 5, image 1 of 3 Toshiba Satellite P50W-C RAM Replacement: step 5, image 2 of 3 Toshiba Satellite P50W-C RAM Replacement: step 5, image 3 of 3
    • Push outwards on the metal tabs located on both sides of the RAM to release the RAM. You can use the spudger tool if you have any issues.
Lawrence Lozada
246 Reputation
2 Guides authored
USF Tampa, Team S3-G2, Cannon Fall 2017 Member of USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 249
