Toshiba Satellite P55W-C5200X Display Replacement
  1. Toshiba Satellite P55W-C5200X Display Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite P55W-C5200X Display Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite P55W-C5200X Display Replacement, Battery: step 1, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Display Replacement: step 2, image 1 of 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Display Replacement: step 3, image 1 of 2 Toshiba Satellite P55W-C5200X Display Replacement: step 3, image 2 of 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Display Replacement: step 4, image 1 of 2 Toshiba Satellite P55W-C5200X Display Replacement: step 4, image 2 of 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Display Replacement: step 5, image 1 of 2 Toshiba Satellite P55W-C5200X Display Replacement: step 5, image 2 of 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Display Replacement, Display: step 6, image 1 of 3 Toshiba Satellite P55W-C5200X Display Replacement, Display: step 6, image 2 of 3 Toshiba Satellite P55W-C5200X Display Replacement, Display: step 6, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the six 5.0 mm screws that are holding the metal brackets on both sides in place.
    • Gently remove both metal brackets.
  7. Toshiba Satellite P55W-C5200X Display Replacement: step 7, image 1 of 3 Toshiba Satellite P55W-C5200X Display Replacement: step 7, image 2 of 3 Toshiba Satellite P55W-C5200X Display Replacement: step 7, image 3 of 3
    • Remove he three wires connected to the motherboard.
  8. Toshiba Satellite P55W-C5200X Display Replacement: step 8, image 1 of 3 Toshiba Satellite P55W-C5200X Display Replacement: step 8, image 2 of 3 Toshiba Satellite P55W-C5200X Display Replacement: step 8, image 3 of 3
    • On the other side remove the four remaining wires from their ports.
  9. Toshiba Satellite P55W-C5200X Display Replacement: step 9, image 1 of 3 Toshiba Satellite P55W-C5200X Display Replacement: step 9, image 2 of 3 Toshiba Satellite P55W-C5200X Display Replacement: step 9, image 3 of 3
    • Lift two sets of metal brackets up, one in each corner.
    • Depending on the force needed on your specific device, you may need to use the spudger.
  10. Toshiba Satellite P55W-C5200X Display Replacement: step 10, image 1 of 2 Toshiba Satellite P55W-C5200X Display Replacement: step 10, image 2 of 2
    • Gently lift the device away from the display assembly.
    • Be aware of the wires attached to the screen so they don't snag on anything.
Hadi Termos
241 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 919
