Toshiba Satellite P55W-C5200X Keyboard Replacement
  1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: step 1, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 2, image 1 of 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 3, image 1 of 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 3, image 2 of 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 4, image 1 of 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 4, image 2 of 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 5, image 1 of 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 5, image 2 of 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: step 6, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: step 6, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: step 6, image 3 of 3
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
  7. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: step 7, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: step 7, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: step 7, image 3 of 3
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  8. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 8, image 1 of 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 8, image 2 of 2
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  9. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 9, image 1 of 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 9, image 2 of 2
    • Gently remove the fan from your device.
  10. Toshiba Satellite P55W-C5200X Keyboard Replacement, Keyboard: step 10, image 1 of 1
    • Once the fan, ram, and battery are removed, remove the motherboard.
    • Detach the three connecting wires.
    • Remove the white, blue-tipped cable ribbon too.
  11. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 11, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 11, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 11, image 3 of 3
    • Remove the three wires that are connected to the motherboard first.
  12. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 12, image 1 of 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 12, image 2 of 2
    • Remove the ribbon by using the black nylon spudger to avoid tearing the ribbon.
  13. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 13, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 13, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 13, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal bracket in place.
    • Gently remove the metal bracket.
  14. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 14, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 14, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 14, image 3 of 3
    • Use the Phillips #00 to remove the four 8.0 mm screws that are holding the motherboard in place.
    • After removing all the screws, gently remove the motherboard.
  15. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 15, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 15, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 15, image 3 of 3
    • Similar to step 4, there is a metal bracket that must be removed to get to some ports.
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal plate in place.
    • Gently remove the metal bracket off the ports underneath.
  16. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 16, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 16, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 16, image 3 of 3
    • Once the ports are accessible, remove four connecting wires from the ports themselves.
    • Be gentle when removing the four wires.
  17. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 17, image 1 of 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 17, image 2 of 2
    • Once the connecting wires are removed, remove the 8.0 mm screw of the USB ports, using the Phillips #00 screwdriver.
    • Gently remove the USB ports.
  18. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 18, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 18, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 18, image 3 of 3
    • Remove the thirty-three 1.0 mm screws with the Phillips Head #000.
    • Gently remove the metal cover.
  19. Toshiba Satellite P55W-C5200X Keyboard Replacement: step 19, image 1 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 19, image 2 of 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: step 19, image 3 of 3
    • Gently pull on the tab to lift the keyboard from the device.
    • Lastly remove the keyboard.
Vatthanak Doeung
223 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 55
All Time: 1,440
