Toshiba Satellite P55W-C5200X RAM Replacement
  1. Toshiba Satellite P55W-C5200X RAM Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite P55W-C5200X RAM Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite P55W-C5200X RAM Replacement, Battery: step 1, image 3 of 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X RAM Replacement: step 2, image 1 of 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X RAM Replacement: step 3, image 1 of 2 Toshiba Satellite P55W-C5200X RAM Replacement: step 3, image 2 of 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X RAM Replacement: step 4, image 1 of 2 Toshiba Satellite P55W-C5200X RAM Replacement: step 4, image 2 of 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X RAM Replacement: step 5, image 1 of 2 Toshiba Satellite P55W-C5200X RAM Replacement: step 5, image 2 of 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X RAM Replacement, RAM: step 6, image 1 of 3 Toshiba Satellite P55W-C5200X RAM Replacement, RAM: step 6, image 2 of 3 Toshiba Satellite P55W-C5200X RAM Replacement, RAM: step 6, image 3 of 3
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
Hadi Termos
241 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 33
All Time: 858
