Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement
Brandon Cole
Brandon Cole and 2 other contributors
Last updated on June 12, 2018
20 - 25 minutes
Moderate
Introduction
Go to step 1
In this guide you will be replacing the Wi-Fi adapter in your laptop. You'll need to use a Phillips #1 screwdriver to complete this repair.
Tools
  1. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Battery: step 1, image 1 of 1
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 2, image 1 of 2 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 2, image 2 of 2
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Wi-Fi Adapter: step 3, image 1 of 2 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement, Wi-Fi Adapter: step 3, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 4, image 1 of 3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 4, image 2 of 3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 4, image 3 of 3
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 5, image 1 of 2 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 5, image 2 of 2
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 6, image 1 of 3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 6, image 2 of 3 Toshiba Satellite P75-A7100 Wi-Fi Adapter Replacement: step 6, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
One Comment
¿Como reemplazo el cable blanco?, esta cortado.
Henry Rivera - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,113
