Toshiba Satellite S50-B Cooling Fan Replacement
  1. Toshiba Satellite S50-B Cooling Fan Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite S50-B Cooling Fan Replacement, Battery: step 1, image 2 of 2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Cooling Fan Replacement: step 2, image 1 of 2 Toshiba Satellite S50-B Cooling Fan Replacement: step 2, image 2 of 2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: step 3, image 3 of 3
    • Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
    • Use a plastic opening tool to remove the bottom panel.
  4. Toshiba Satellite S50-B Cooling Fan Replacement: step 4, image 1 of 3 Toshiba Satellite S50-B Cooling Fan Replacement: step 4, image 2 of 3 Toshiba Satellite S50-B Cooling Fan Replacement: step 4, image 3 of 3
    • Locate the 2 screws on each fan. Unscrew them.
    • Disconnect the fan by applying gentle pressure to the circled connection with your finger and pulling.
    • Remove the fans. Be sure to keep track of the right and left fans, marked R and L.
diana calvo
144 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,492
