Toshiba Satellite S50-B Hard Drive Replacement
  1. Toshiba Satellite S50-B Hard Drive Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite S50-B Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Hard Drive Replacement: step 2, image 1 of 2 Toshiba Satellite S50-B Hard Drive Replacement: step 2, image 2 of 2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Locate the 12 screws on the bottom of the device. Unscrew using a Phillips screwdriver, and set screws aside.
    • Use a plastic opening tool to remove bottom casing.
  4. Toshiba Satellite S50-B Hard Drive Replacement: step 4, image 1 of 2 Toshiba Satellite S50-B Hard Drive Replacement: step 4, image 2 of 2
    • Use the plastic casing over the hard drive to lift the hard drive up.
    • Once hard drive is slightly lifted up, make sure the laptop is in correct orientation with the battery away from you, and pull the hard drive towards right.
4 other people completed this guide.
Victoria Murillo
143 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 30
All Time: 6,066
