Toshiba Satellite S50-B RAM Replacement
  1. Toshiba Satellite S50-B RAM Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite S50-B RAM Replacement, Battery: step 1, image 2 of 2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B RAM Replacement: step 2, image 1 of 2 Toshiba Satellite S50-B RAM Replacement: step 2, image 2 of 2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B RAM Replacement, RAM: step 3, image 1 of 3 Toshiba Satellite S50-B RAM Replacement, RAM: step 3, image 2 of 3 Toshiba Satellite S50-B RAM Replacement, RAM: step 3, image 3 of 3
    • Unscrew all 6.5mm screws on the bottom of the laptop using a Phillips #0 Screwdriver
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
  4. Toshiba Satellite S50-B RAM Replacement: step 4, image 1 of 2 Toshiba Satellite S50-B RAM Replacement: step 4, image 2 of 2
    • Push down on the clips on either side of the RAM stick evenly.
    • Pull out the RAM stick. Make sure the notches on the RAM stick align with the notches in the RAM holder.
3 other people completed this guide.
Eric Sun
144 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,060
