Toshiba Satellite S55T-B5335 Touchpad Replacement
  1. Toshiba Satellite S55T-B5335 Touchpad Replacement, Battery: step 1, image 1 of 1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Touchpad Replacement: step 2, image 1 of 3 Toshiba Satellite S55T-B5335 Touchpad Replacement: step 2, image 2 of 3 Toshiba Satellite S55T-B5335 Touchpad Replacement: step 2, image 3 of 3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Touchpad Replacement, Bottom Cover: step 3, image 1 of 2 Toshiba Satellite S55T-B5335 Touchpad Replacement, Bottom Cover: step 3, image 2 of 2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Touchpad Replacement: step 4, image 1 of 1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Touchpad Replacement: step 5, image 1 of 1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Touchpad Replacement, Touchpad: step 6, image 1 of 2 Toshiba Satellite S55T-B5335 Touchpad Replacement, Touchpad: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using a spudger, lift the black tab that holds the touchpad ribbon cable in place.
    • Using tweezers, pull gently on the purple tab to separate the ribbon cable from the connector.
  7. Toshiba Satellite S55T-B5335 Touchpad Replacement: step 7, image 1 of 2 Toshiba Satellite S55T-B5335 Touchpad Replacement: step 7, image 2 of 2
    • Gently push the back side of the touchpad in order to create a gap on the top side of the touchpad.
  8. Toshiba Satellite S55T-B5335 Touchpad Replacement: step 8, image 1 of 2 Toshiba Satellite S55T-B5335 Touchpad Replacement: step 8, image 2 of 2
    • Using a plastic opening tool, hold the touchpad up in the position from step 2.
    • While the touchpad is held up, use a spudger to scrape loose the adhesive holding the touchpad to the base.
  9. Toshiba Satellite S55T-B5335 Touchpad Replacement: step 9, image 1 of 1
    • Once the adhesive is separated enough from the touchpad, peel it back and remove it.
George Gillespie
721 Reputation
7 Guides authored
USF Tampa, Team 2-1, Blackwell Fall 2016 Member of USF Tampa, Team 2-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G1
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,514
