Toshiba Satellite U405D-S2902 Display Replacement
  1. Toshiba Satellite U405D-S2902 Display Replacement, Display: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
  2. Toshiba Satellite U405D-S2902 Display Replacement: step 2, image 1 of 2 Toshiba Satellite U405D-S2902 Display Replacement: step 2, image 2 of 2
    • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
  3. Toshiba Satellite U405D-S2902 Display Replacement: step 3, image 1 of 3 Toshiba Satellite U405D-S2902 Display Replacement: step 3, image 2 of 3 Toshiba Satellite U405D-S2902 Display Replacement: step 3, image 3 of 3
    • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
    • Carefully pull the top away from the back.
  4. Toshiba Satellite U405D-S2902 Display Replacement: step 4, image 1 of 3 Toshiba Satellite U405D-S2902 Display Replacement: step 4, image 2 of 3 Toshiba Satellite U405D-S2902 Display Replacement: step 4, image 3 of 3
    • Turn the laptop around.
    • Remove the webcam/microphone data cable.
  5. Toshiba Satellite U405D-S2902 Display Replacement: step 5, image 1 of 2 Toshiba Satellite U405D-S2902 Display Replacement: step 5, image 2 of 2
    • Remove the lower lighting power supply.
    • Remove the signal light power supply and data cable.
  6. Toshiba Satellite U405D-S2902 Display Replacement: step 6, image 1 of 2 Toshiba Satellite U405D-S2902 Display Replacement: step 6, image 2 of 2
    • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
    • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
  7. Toshiba Satellite U405D-S2902 Display Replacement: step 7, image 1 of 2 Toshiba Satellite U405D-S2902 Display Replacement: step 7, image 2 of 2
    • Carefully remove the screen from the side brackets.
    • Remove the LCD ribbon connector from the display.
4 other people completed this guide.
Brandon Kirklen
311 Reputation
8 Guides authored
Cal Poly, Team 7-8, Maness Winter 2013 Member of Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 708
