Introduction
The keyboard requires more disassembly than what may seem obvious, Luckily, this laptops keyboard is one piece and easily replaceable.
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
Remove two 2.5 mm screws from the side of the optical drive using a Phillips #0 screwdriver.
Move the 4 small tabs, that are placed along the empty battery space, in the direction of where the battery pack would be. They should stay unhooked without having to hold them.
2 Comments
To replace the keyboard you only need to remove one screw (marked KB) on the underside of the laptop. The keyboard can then be easily removed by taking off the plastic bezel by the top row of keys and unclipping from there. Literally a 5 minute job without the need to fully disassemble.
Bravo! You are 100% right
Thanks to your advice, I got rid of unnecessary and unnecessary disassembly work.
