Toshiba Tecra 8200 RAM Replacement
  1. Toshiba Tecra 8200 RAM Replacement, Battery: step 1, image 1 of 1
    • Turn off the device and unplug the power cord.
    • To remove the battery, flip the device, so that the bottom is facing upward.
  2. Toshiba Tecra 8200 RAM Replacement: step 2, image 1 of 3 Toshiba Tecra 8200 RAM Replacement: step 2, image 2 of 3 Toshiba Tecra 8200 RAM Replacement: step 2, image 3 of 3
    • Slide the battery to the right side until you hear a click.
    • Carefully remove the battery from its compartment.
  3. Toshiba Tecra 8200 RAM Replacement, RAM: step 3, image 1 of 1
    • Position device so the screen is face down.
    • Locate RAM Panel.
  4. Toshiba Tecra 8200 RAM Replacement: step 4, image 1 of 2 Toshiba Tecra 8200 RAM Replacement: step 4, image 2 of 2
    • Remove two Phillips #00 screws labeled F4.
    • Remove panel.
  5. Toshiba Tecra 8200 RAM Replacement: step 5, image 1 of 2 Toshiba Tecra 8200 RAM Replacement: step 5, image 2 of 2
    • Pinch clips on each side of RAM chips to release.
    • Gently remove RAM chips at a 45 degree angle. Use a plastic opening tool if RAM chips do not pop open.
Sally
306 Reputation
3 Guides authored
Ohio State, Team 1-3, Buehl Winter 2015 Member of Ohio State, Team 1-3, Buehl Winter 2015
OSU-BUEHL-W15S1G3
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 351
