Toshiba Tecra Z50-A Hard Drive Replacement
  1. Toshiba Tecra Z50-A Hard Drive Replacement, Back Panel: step 1, image 1 of 1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Hard Drive Replacement: step 2, image 1 of 1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Hard Drive Replacement, Battery: step 3, image 1 of 1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Hard Drive Replacement: step 4, image 1 of 1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Hard Drive Replacement: step 5, image 1 of 1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Hard Drive Replacement: step 6, image 1 of 1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Hard Drive Replacement: step 7, image 1 of 1
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Hard Drive Replacement, Hard Drive: step 8, image 1 of 1
    • Lift up on the hard drive.
  9. Toshiba Tecra Z50-A Hard Drive Replacement: step 9, image 1 of 2 Toshiba Tecra Z50-A Hard Drive Replacement: step 9, image 2 of 2
    • Pull out the plug from the hard drive.
Dominic Hryzan
545 Reputation
3 Guides authored
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Members
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 632
