Toshiba Tecra Z50-A Speakers Replacement
  1. Toshiba Tecra Z50-A Speakers Replacement, Back Panel: step 1, image 1 of 1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Speakers Replacement: step 2, image 1 of 1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Speakers Replacement, Battery: step 3, image 1 of 1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Speakers Replacement: step 4, image 1 of 1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Speakers Replacement: step 5, image 1 of 1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Speakers Replacement: step 6, image 1 of 1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Speakers Replacement: step 7, image 1 of 1
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Speakers Replacement, Hard Drive: step 8, image 1 of 1
    • Lift up on the hard drive.
  9. Toshiba Tecra Z50-A Speakers Replacement: step 9, image 1 of 2 Toshiba Tecra Z50-A Speakers Replacement: step 9, image 2 of 2
    • Pull out the plug from the hard drive.
  10. Toshiba Tecra Z50-A Speakers Replacement, Speakers: step 10, image 1 of 1
    • Lift up on the tape holding the bundled speaker wire down.
  11. Toshiba Tecra Z50-A Speakers Replacement: step 11, image 1 of 1
    • Pull the bundled wire out of its socket on the motherboard.
  12. Toshiba Tecra Z50-A Speakers Replacement: step 12, image 1 of 3 Toshiba Tecra Z50-A Speakers Replacement: step 12, image 2 of 3 Toshiba Tecra Z50-A Speakers Replacement: step 12, image 3 of 3
    • Lift up on the left speaker with a spudger.
  13. Toshiba Tecra Z50-A Speakers Replacement: step 13, image 1 of 3 Toshiba Tecra Z50-A Speakers Replacement: step 13, image 2 of 3 Toshiba Tecra Z50-A Speakers Replacement: step 13, image 3 of 3
    • Lift up on the right speaker with a spudger and remove both speakers from the laptop.
Luis Juen Baez
585 Reputation
4 Guides authored
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Members
21 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 263
