Introduction
The pumps impeller is responsible for increasing the flow of water through the pump. If the impeller fails to work properly, water will not move through the pump as it otherwise would and the impeller must be replaced.
Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
2 other people completed this guide.
