Toto E-Max Fill Valve Disassembly
  1. Toto E-Max Fill Valve Disassembly, Tank Lid: step 1, image 1 of 3 Toto E-Max Fill Valve Disassembly, Tank Lid: step 1, image 2 of 3 Toto E-Max Fill Valve Disassembly, Tank Lid: step 1, image 3 of 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toto E-Max Fill Valve Disassembly, Shutting off the Water Supply to a Toilet: step 2, image 1 of 2 Toto E-Max Fill Valve Disassembly, Shutting off the Water Supply to a Toilet: step 2, image 2 of 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toto E-Max Fill Valve Disassembly, Refill Tube: step 3, image 1 of 3 Toto E-Max Fill Valve Disassembly, Refill Tube: step 3, image 2 of 3 Toto E-Max Fill Valve Disassembly, Refill Tube: step 3, image 3 of 3
    • Disconnect the fill valve's rubber refill tube from the top of the overflow tube.
  4. Toto E-Max Fill Valve Disassembly, Draining a Toilet Tank: step 4, image 1 of 2 Toto E-Max Fill Valve Disassembly, Draining a Toilet Tank: step 4, image 2 of 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  5. Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: step 5, image 1 of 3 Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: step 5, image 2 of 3 Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: step 5, image 3 of 3
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
  6. Toto E-Max Fill Valve Disassembly, Supply Tube: step 6, image 1 of 3 Toto E-Max Fill Valve Disassembly, Supply Tube: step 6, image 2 of 3 Toto E-Max Fill Valve Disassembly, Supply Tube: step 6, image 3 of 3
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  7. Toto E-Max Fill Valve Disassembly, Fill Valve: step 7, image 1 of 2 Toto E-Max Fill Valve Disassembly, Fill Valve: step 7, image 2 of 2
    • Using an adjustable wrench, turn the locknut on the threaded shank counter-clockwise until it becomes loose.
  8. Toto E-Max Fill Valve Disassembly: step 8, image 1 of 3 Toto E-Max Fill Valve Disassembly: step 8, image 2 of 3 Toto E-Max Fill Valve Disassembly: step 8, image 3 of 3
    • Turn the locknut counter-clockwise until it releases from the threaded shank.
  9. Toto E-Max Fill Valve Disassembly: step 9, image 1 of 2 Toto E-Max Fill Valve Disassembly: step 9, image 2 of 2
    • Lift the entire fill valve out of the tank.
    • When installing a new valve, be sure to adjust the float so that the water line stops one inch below the overflow tube.
  10. Toto E-Max Fill Valve Disassembly, Valve: step 10, image 1 of 1
    • This is our friend the Toto E-Max Fill valve. Unfortunately, she is leaking. Specifically, the shutoff is incomplete, so water continues to flow even after the float is fully lifted.
  11. Toto E-Max Fill Valve Disassembly, Remove Top Cap: step 11, image 1 of 1
    • The next step is to remove the green top cap. It's held on by tabs, light flexing should allow you to remove it.
  12. Toto E-Max Fill Valve Disassembly, Remove the valve lever: step 12, image 1 of 1
    • Here is the valve lever[*]. We need to remove it. It's held in by two pegs. Each one is attached to a flexible tang. use a thin blade or screwdriver to push each tang in, while gently lifting the lever.
    • [*} I have no idea if this is the right name.
  13. Toto E-Max Fill Valve Disassembly, Continue removing valve lever: step 13, image 1 of 1
    • Here we see one peg released. Note that I'm applying very gentle lifting pressure, not prying it upward.
  14. Toto E-Max Fill Valve Disassembly, Release one end of valve lever: step 14, image 1 of 1
    • Valve lever released! You are a champion. BTW, I made up the name "valve lever". I hope you're not laughing at me.
  15. Toto E-Max Fill Valve Disassembly, Release other end of valve lever: step 15, image 1 of 1
    • This is the other end of the valve lever. You should be able to easily release it from the green collar.
  16. Toto E-Max Fill Valve Disassembly, Remove the collar: step 16, image 1 of 1
    • Next, gently pop off the green collar that links the valve lever to the threaded float lift shaft.
  17. Toto E-Max Fill Valve Disassembly, Disconnect float pole from top cap: step 17, image 1 of 2 Toto E-Max Fill Valve Disassembly, Disconnect float pole from top cap: step 17, image 2 of 2
    • Gently snap the white float pole out of the jaws of the top cap. When you do this, the float assembly will drop.
  18. Toto E-Max Fill Valve Disassembly, Rotate valve cover: step 18, image 1 of 1
    • Rotate the valve cover an eighth of a turn counter-clockwise to release it.
  19. Toto E-Max Fill Valve Disassembly, Admire valve seal: step 19, image 1 of 2 Toto E-Max Fill Valve Disassembly, Admire valve seal: step 19, image 2 of 2
    • Yay! We got to the valve seal. Clean it off or replace it, and reverse steps to reassemble.
3 other people completed this guide.
John Clements
504 Reputation
2 Guides authored
One Comment
Thank you! I did not expect to find a guide for a Toto toilet repair on a (mainly) electronics site, but here it is!
It worked perfectly when my toilet started running continuously on a Saturday evening.
I was able to take everything apart without even removing it from the tank, so it was a 15min fix!
Thank you!
Graham Allen - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 56
All Time: 2,346
