Toy Lightsaber Battery Replacement
  1. Toy Lightsaber Battery Replacement, Battery: step 1, image 1 of 3 Toy Lightsaber Battery Replacement, Battery: step 1, image 2 of 3 Toy Lightsaber Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the Lightsaber blade by carefully twisting it off the hilt.
    • Be gentle during this process to avoid damaging the blade or the hilt.
  2. Toy Lightsaber Battery Replacement: step 2, image 1 of 3 Toy Lightsaber Battery Replacement: step 2, image 2 of 3 Toy Lightsaber Battery Replacement: step 2, image 3 of 3
    • Use a Phillips #2 screwdriver to remove the 3.5 mm screws on the hilt.
  3. Toy Lightsaber Battery Replacement: step 3, image 1 of 3 Toy Lightsaber Battery Replacement: step 3, image 2 of 3 Toy Lightsaber Battery Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the old C batteries.
    • If the batteries were leaking, be sure you thoroughly clean the inside of the hilt with a pair of tweezers to scrape off the battery acid and wipe away any acid that remains with a tissue or napkin.
    • Battery acid is toxic and dangerous for your health. Wear gloves to protect yourself.
  4. Toy Lightsaber Battery Replacement: step 4, image 1 of 3 Toy Lightsaber Battery Replacement: step 4, image 2 of 3 Toy Lightsaber Battery Replacement: step 4, image 3 of 3
    • Place the new C batteries inside the newly cleaned hilt.
  5. Toy Lightsaber Battery Replacement: step 5, image 1 of 3 Toy Lightsaber Battery Replacement: step 5, image 2 of 3 Toy Lightsaber Battery Replacement: step 5, image 3 of 3
    • Use your Philips #2 screwdriver to screw the 3.5 mm screws back into the hilt.
  6. Toy Lightsaber Battery Replacement: step 6, image 1 of 3 Toy Lightsaber Battery Replacement: step 6, image 2 of 3 Toy Lightsaber Battery Replacement: step 6, image 3 of 3
    • Lastly, twist the Lightsaber blade back on top of the hilt.
    • Press the red button on the hilt to test if the blade glows.
    • If the blade doesn't glow, start over and try again with different C batteries.
Zachary Adaes
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 45
All Time: 4,224
