Trek 4300 Bicycle Kickstand Replacement
  1. Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: step 1, image 1 of 2 Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: step 1, image 2 of 2
    • Flip the bike over so it is balanced and resting on the handlebar and the bike seat.
    • Using a socket screwdriver with a hex adapter, loosen the bolt that is holding the kickstand and bracket in place.
    • This may require a moderate amount of strength. Make sure you have the proper hex adapter as to not strip the bolt.
  2. Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: step 2, image 1 of 2 Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: step 2, image 2 of 2
    • Once the bolt is loose, unscrew it the rest of the way by hand.
    • Remove the bolt. There should now be three separate pieces: the bolt, the bracket, and the kickstand.
    • Make sure to note the position of the bracket before you remove the bolt completely
To replace the new kickstand, follow these instructions in reverse order.
Emily OConnor
500 Reputation
4 Guides authored
Clemson, Team 3-2, Benson Fall 2014 Member of Clemson, Team 3-2, Benson Fall 2014
CLEM-BENSON-F14S3G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 2,905
