Trek 820 Handlebars Replacement
  1. Trek 820 Handlebars Replacement, Handlebar and stem: step 1, image 1 of 2 Trek 820 Handlebars Replacement, Handlebar and stem: step 1, image 2 of 2
    • Use a 3/16" Allen Wrench to remove the silver cap.
  2. Trek 820 Handlebars Replacement: step 2, image 1 of 1
    • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
  3. Trek 820 Handlebars Replacement: step 3, image 1 of 2 Trek 820 Handlebars Replacement: step 3, image 2 of 2
    • Remove the handlebar by lifting vertically away from the frame.
    • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
  4. Trek 820 Handlebars Replacement: step 4, image 1 of 2 Trek 820 Handlebars Replacement: step 4, image 2 of 2
    • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
    • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
  5. Trek 820 Handlebars Replacement: step 5, image 1 of 1
    • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
    • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
    • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
Kaveh Karimiyanha
813 Reputation
7 Guides authored
Cal Poly, Team 1-1, Propen Fall 2012 Member of Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Members
9 Guides authored
1 Guide Comment
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 26
All Time: 6,364
