Introduction
This guide will show you how to replace an old or damaged brake cable. If you need to swap out your brake cable, this will help you replace it safely.
Unscrew the screw holding the brake cable in place with a 5mm allen wrench and pull out the cable.
Almost done!
To place the new cable, follow these instructions in reverse order.
