Triace A310 Disk Brake Replacement
  1. Triace A310 Disk Brake Replacement, Tire: step 1, image 1 of 1
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Disk Brake Replacement: step 2, image 1 of 2 Triace A310 Disk Brake Replacement: step 2, image 2 of 2
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Disk Brake Replacement: step 3, image 1 of 2 Triace A310 Disk Brake Replacement: step 3, image 2 of 2
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Disk Brake Replacement, Disk Brake: step 4, image 1 of 1
    • Place the tire flat on the ground making sure the disk is facing you.
  5. Triace A310 Disk Brake Replacement: step 5, image 1 of 3 Triace A310 Disk Brake Replacement: step 5, image 2 of 3 Triace A310 Disk Brake Replacement: step 5, image 3 of 3
    • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
    • Make sure to keep track of all of the removed pieces.
  6. Triace A310 Disk Brake Replacement: step 6, image 1 of 2 Triace A310 Disk Brake Replacement: step 6, image 2 of 2
    • After all of the screws have been removed, take the disk and pull it away from the tire.
Daniel
222 Reputation
2 Guides authored
Cal Poly, Team 1-37, Maness Winter 2014 Member of Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 814
