Tribit XSound Go TS-BTS20 Passive Radiator Replacement
  1. Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: step 1, image 1 of 2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: step 1, image 2 of 2
    • Insert a spudger in the seam between the front speaker grill and chassis.
    • Pry around the perimeter until the front grill releases.
    • Remove the front grill.
  2. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: step 2, image 1 of 1
    • Unscrew all the screws with the Phillips screwdriver, on the opened panel.
    • Lift off the speaker housing.
  3. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: step 3, image 1 of 2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement: step 3, image 2 of 2
    • Hold the frame which has the passive radiator in the middle.
  4. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: step 4, image 1 of 1
    • Use a spudger to push the damaged passive radiator off the frame
  5. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: step 5, image 1 of 1
    • Insert the new passive radiator into the frame.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 64
