Trio AXS 3G Camera Replacement
  1. Trio AXS 3G Camera Replacement, Back Case: step 1, image 1 of 1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Camera Replacement: step 2, image 1 of 2 Trio AXS 3G Camera Replacement: step 2, image 2 of 2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Camera Replacement: step 3, image 1 of 1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
  4. Trio AXS 3G Camera Replacement, Camera: step 4, image 1 of 2 Trio AXS 3G Camera Replacement, Camera: step 4, image 2 of 2
    • Unscrew 5 #000 4 mm and 3 mm screws around the strip.
  5. Trio AXS 3G Camera Replacement: step 5, image 1 of 1
    • Undo the tape on top of the connector from the camera to motherboard.
  6. Trio AXS 3G Camera Replacement: step 6, image 1 of 1
    • Slightly lift up the motherboard.
  7. Trio AXS 3G Camera Replacement: step 7, image 1 of 2 Trio AXS 3G Camera Replacement: step 7, image 2 of 2
    • Disconnect the camera from the motherboard on the topside and pull the camera strip out.
1 Guide Comment
Where can I get the camera?
Amanda Springsteen - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 248
