Trio STEALTH-9 Back Cover Replacement
  1. Trio STEALTH-9 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Remove the two Phillips #00 screws on the side of the tablet.
  2. Trio STEALTH-9 Back Cover Replacement: step 2, image 1 of 1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
  3. Trio STEALTH-9 Back Cover Replacement: step 3, image 1 of 1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
  4. Trio STEALTH-9 Back Cover Replacement: step 4, image 1 of 1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
To reassemble your device, follow these instructions in reverse order with your replacement cover!
2 other people completed this guide.
Mei Liang
228 Reputation
2 Guides authored
Clemson, Team 15-5, Shirley Winter 2015 Member of Clemson, Team 15-5, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G5
4 Members
4 Guides authored
2 Guide Comments
Tengo.una y costo tiene el.displey
eliehtmaria - Reply Share
Deseo.saber el.c
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 30
All Time: 1,344
