Trio Stealth Pro 9.7" Battery Replacement
  1. Trio Stealth Pro 9.7" Battery Replacement, Battery: step 1, image 1 of 1
    • Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
  2. Trio Stealth Pro 9.7" Battery Replacement: step 2, image 1 of 2 Trio Stealth Pro 9.7" Battery Replacement: step 2, image 2 of 2
    • Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
  3. Trio Stealth Pro 9.7" Battery Replacement: step 3, image 1 of 1
    • Cut red, black, and gray wires connecting the battery to the motherboard.
  4. Trio Stealth Pro 9.7" Battery Replacement: step 4, image 1 of 1
    • Remove tape on top of battery.
  5. Trio Stealth Pro 9.7" Battery Replacement: step 5, image 1 of 2 Trio Stealth Pro 9.7" Battery Replacement: step 5, image 2 of 2
    • Use the plastic opening tool and the spudger to pry up and remove the battery.
2 other people completed this guide.
Edward Insogna
626 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,352
