Trio Stealth Pro 9.7" Motherboard Replacement
  1. Trio Stealth Pro 9.7" Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
  2. Trio Stealth Pro 9.7" Motherboard Replacement: step 2, image 1 of 2 Trio Stealth Pro 9.7" Motherboard Replacement: step 2, image 2 of 2
    • Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
  3. Trio Stealth Pro 9.7" Motherboard Replacement: step 3, image 1 of 3 Trio Stealth Pro 9.7" Motherboard Replacement: step 3, image 2 of 3 Trio Stealth Pro 9.7" Motherboard Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Unclip camera flex cable
    • Use plastic opening tool to lift open black clip where the flex cables are attached to the motherboard.
    • Then gently pull out the flex cable with tweezers.
  4. Trio Stealth Pro 9.7" Motherboard Replacement: step 4, image 1 of 2 Trio Stealth Pro 9.7" Motherboard Replacement: step 4, image 2 of 2
    • Unclip large orange flex cable.
  5. Trio Stealth Pro 9.7" Motherboard Replacement: step 5, image 1 of 1
    • Remove flex cable clip in top left area of motherboard.
    • Use plastic opening tool to lift open black clip where the flex cables are attached to the motherboard. gently pull out the flex cable with tweezers.
  6. Trio Stealth Pro 9.7" Motherboard Replacement: step 6, image 1 of 1
    • Remove 4 silver 4 cm Philips screws holding down the motherboard.
  7. Trio Stealth Pro 9.7" Motherboard Replacement: step 7, image 1 of 1
    • Cut red black and gray wires attached to the bottom of the motherboard connecting to the battery.
  8. Trio Stealth Pro 9.7" Motherboard Replacement: step 8, image 1 of 1
    • Cut three red and three black wires attached to the right side of the motherboard.
  9. Trio Stealth Pro 9.7" Motherboard Replacement: step 9, image 1 of 2 Trio Stealth Pro 9.7" Motherboard Replacement: step 9, image 2 of 2
    • Cut 4 wire cable attached to the right side of the motherboard.
    • Remove motherboard.
2 other people completed this guide.
Edward Insogna
626 Reputation
5 Guides authored
One Comment
We're can I get this motherboard
Heather carr - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 748
